Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Hi, Just save the model as neutral model. i.e, File, save a copy,Part1.neu* file. This part.neu can be opened in any version of Pro-e. Regards, Balaji M
You can directly open a WF 4 model in WF2 using the GRANITE based cross release interoperability.Here is more info - http://ptc.com/products/granite/gcri/index.htm Here is the dowload link - http://ptc.com/products/granite/gcri/free-download.htm Thiagu Application Engineer Tristar Inc
