I have no answer.
So I take it you did not search Help, the Knowledge Base or the Community for "excel", "external analysis" or "behavioral modeling"? This question has been asked and answered before.
Here's some of the resources you need to check out:
- Solved: Controlling dimensions of parts present in an asse... - PTC Community
- Solved: How to integrate MS excel with creo 2.0. - PTC Community
- Solved: Excel Analysis - PTC Community
- http://support.ptc.com/cs/cs_26/howto/beh11983/beh11983.htm
We need more detail on what you actually want to do. I assume you are not looking to have excel control mouse movements, but rather have excel drive dimensions or parameters? That is readily done, research external analysis and behavioral modeling and then come back if you have questions.
I want to get all dimensions in excel and if I perform changes any dimension in part then excel sheet should be updated.Or I performed any change in sheet then part should be updated.
YES! It is most definitely possible. Simplified Logic Inc specializes in bi-directional Excel to Creo or Creo to Excell data transfer this with an application called Nitro-CELL. Please see this Website: Simplified Logic, Inc. and YouTube Channel: Simplified Logic, Inc. - YouTube
