Import Solidworks model into Proe wf4
JohannaLiljedah
Is there a way to import a solidworks model into Pro Engineer WF4?
if you have a solidworks license, you can get the Document Manager key from solidworks and "install" it. Then you can open solidworks 2008 files, and previous versions below 2008.
Hey Johanna,
Did you ever request this key? What did you actually ask for, was it through your VAR?
thanks,
Brian
