Insert text to 3d model
FredrikIversen
2-Explorer
My problem is that my font I want to write the text with is in TYPE1 format and it´s not supported by PRO/E. Is there any way to write the text with this TYPE1 font?
2 REPLIES 2
Not applicable
(To:FredrikIversen)
The Installation and Administration Guide provides information on creating new fonts in the section "Using Fonts in Pro/ENGINEER". An alternative would be to export the text from an outside application to a format that could be imported by sketcher (DXF IGS). Cheers-
AnkurAggarwal
(To:)
try this- copy .ttf file of your font at following path- X:\Program Files\proeWildfire 4.0\text\fonts restart pro-e after copying the font.
