Japanese note need to be visible in english version
dthangaraj
Hi All,
I'm using creo 2.0 M150 it is a English version,
I need to my customer details in Japanese & Chinese ,
How I can get it these things In my system.
Thanks & Regards,
Devarajan
I possibly found a solution because we had the same problem.
You have to start Creo in Japanese to be able to get the Japanese text properly displayed in a drawing. To start Creo in Japanese set the environment variable LANG to "japanese".
To avoid having the GUI in Japanese add the following lines to one of you Config.pro:
dialog_translation no
help_translation no
menu_translation no
msg_translation no
I verified this for Japanese and would assume that it works for Chinese, too, but have not yet tried-
