Link calculations
- November 21, 2011
- 1 reply
- 1647 views
I'm designing a pivoting clamp arm in proE using links and pivots,has anyone seen a way to calculate output force through a series of mechanical links and pivots, knowing the links sizes and angles plus the input cylinder force? I'm trying to achieve the best mechanical advantage, rather than disadvantage at the end of the stroke.
