Mass calculation
ptc-2668817
Mass calculation
After i insert a density of 7.89 i get this result, MASS = 2.8945595e+08 TONNE. How do i now what this is in kilogram?
Stefan Go to setup under the edit menu and change your model units such that you get the right units for your mass. Your density is such that this model is getting close to the weight of the earth (E8). Eric
OK. I change that now and get this. MASS = 2.8945595e+08 KILOGRAM. Is this 2.89 KG or is it 289 KG? Shall the decimal sign move to get the right value for me?
2.8945e+8 is 289450000 KG E notation is move decimal to right # places for positive numbers and move left for negative. E-8 would be .000000028945... KG
For getting proper weight calculation 1st you have to set units of parts to KG & then go to edit -> setup -> material & move steel to the right side. It will assign steel material to model & you can easily get the correct weight. If you are confused with scientific notation like 12.458 +e5 then copy this text and paste in calculator & u will get the perfect answer in your required unit.
