In the near future, we will be moving from Wildfire 4.0 to WF 5.0/Creo. Any words to the wise, or any thing that I need to watch for?
Ken,
I have compiled some WF4 / WF5 comparison material that I will send along (if anyone elses is interested, just email me)- also see http://www.cadquest.com/books/rel28.htm this was VERY valuable.
If anyone has any training materials or tutorials or ideas aounr user training, this would be helpful as well.
Francis
In Reply to ken miller:
David T. Francis
*simplified rep creation in 5.0 (out of the box is terrible). i would set in config new_wf5_simp_rep_ui no
*Don't waste hours trying to get the dashboard at the bottom of the UI. PTC forbids in 5.0. thanks!
*Still no fullscreenusage. thanks!
*still no extrude with draft Thanks!
*default lighting in models is horrendous. The lighting is so bright and so white that you can barely even see edges on the model in shaded mode. I had to create a mapkey in import lighting that is not the full power of the sun into models. I then set the save_scene_with_file yes so the lighitng that was imported will be saved with parts and assemblies. I also had to go into my start models and "fix the lighting" with the lighting corrected.
*drawing mode ressemblesa MS ribbonstyle thatreally does agood job of slowing you down.
*model appearence.dmt color pallete leads extremely slow pre m100 release.
*assigning colors to models is completely different and more combersome
*in general the GUI does a really god job of putting flyouts and windows on top of other window making the contents behind the windows inaccessible.
*Layering hiding and show (unhide is not a word) of inheritence features does not work correctly. the "hide" or "show" does not take effectuntil you start a feature and the cancel the feature... i wrote a mapkey to do this for me...WF4.0 did NOT do this.
*about 50% of ther time i "erase not displayed" Pro/Creo/Wildfire dissappears
In essense, it is like wf4.0 just a little worse
