Operation set up
bparrish
8-Gravel
Operation set up
All,
I am having an issue with a system here. I have had two user log in and
they are both unable to create an operation in the NC environment.
Whenever we try to define a work cell or operation it becomes visible in
the model tree, but we get an error saying that the operation has been
cancelled. Has anyone else seen this behavior or better yet have a
resolution to it?
Brian
2 REPLIES 2
cdg
(To:bparrish)
what build are you on? I have noticed 4.0 has a lot of bugs where my volume disappears also! You may want to try using a build 1 newer or older. Sometimes it may be something in your config to. I have had problems where a newer build would bomb because of a line or 2!
Brian,
Sometimes it is helpful go to theprocess Manager and create new operations or delete ghostedones from there.
Daniel Santos - Sr. NC Programmer / CAM Support
Liebherr Aerospace Brasil
