Order in which Creo displays hole/shaft tolerances
ptc-5012625
Hi there,
Can anyone tell me whether Creo Elements/Pro can display hole and shaft tolerances as Nominal +/- tol (H7) as in item 1 below, rather than Nominal H7 (+/- tol), item 2 below??
Many thanks.
Adam
I think/know that is working only like 2nd example.
Vladimir
Best Regards,
Vladimir Palffy
Vladimir
Best Regards,
Vladimir Palffy
... if you need it, you can create new Idea
Best Regards,
Vladimir Palffy
