Persistent View Manager and window size?
David_M
A setting that I'd like to apply is to have the View Manager remain accessible even when I change the active document. I'd also like to make all Pro/E windows a little narrower in order to accommodate the View Manager at the right side.
Does anyone know if ths can be done?
KrisR
(To:David_M)
The windows sizing issue you would have to change each time you opened Pro. You have two choices for Pro windows; the default (stuck at the left with a margin at the right) or maximized.
I do not know of a way to "pin" the view manager. What I have done is assign them to mapkeys, as I use different views quite frequently.
David_M
(To:KrisR)
Since I'm now logged in I may as well add a bit more information.
For the benefit of anyone else reading this you can change the window width just fine using a window manager. I do this from time to time but it seems like there should be a native solution. I would be surprised if there wasn't. The windows_scale option in config.pro doesn't really cut it as it scales the window in both X and Y.
KrisR
(To:David_M)
Window Manager as in an external program?
David_M
(To:KrisR)
