Please tell me I am just over looking it.
brianlynn
I cannot figure out how to blank a single component in just one view. Has
anyone done this in WF 1.0?
Thanks for the help,
Brian S. Lynn
CAD Administrator/Designer
I have tried that, didn't work for me. I am using build M140 is there a
bug with this build? I am also working with a detail view will that cause
a problem?
Brian S. Lynn
Sure,
It is under View, Drawing Display, Component Display. Once you select
this, you get the menu manager with the old options.
Michael Drum
Engineering Business Analyst
Rubbermaid/Irwin
_____
The answer is that detail views won't let you have a different component
display than the parent. As a work around, I had to do was create a
general partial view and fake the rest to make it look like a detail view.
Personally I think that stinks, but then I am not writing the code just
using it. Summaries follow below.
Brian S. Lynn
