Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I have tried that, didn't work for me. I am using build M140 is there a bug with this build? I am also working with a detail view will that cause a problem?
The answer is that detail views won't let you have a different component display than the parent. As a work around, I had to do was create a general partial view and fake the rest to make it look like a detail view. Personally I think that stinks, but then I am not writing the code just using it. Summaries follow below.
Brian S. Lynn CAD Administrator/Designer
