Plotting style
ptc-1424088
Plotting style
Can anybody please help me how to set different plotting style in Proe, what is "table.pnt" file. Thanking you
hi there, Search the forum there are several topics on this issue. Basically the table.pnt is the file where you assign a pen to a specific drawing element, and you also define it's linewidth. The path to this file must be defined in config.pro. A very brief example for table.pnt: pen 1 thickness .5; pen 2 thickness .35; pen 3 thickness .25; pen 4 thickness .35; VB
hello, I have another query also 1. When u placed view in drawing sheet it should ask for scale for which I want? 2. For default view in drawing sheet "view name" & "scale" should highlight. 3. Graph related Relations in models like in variable section sweep etc.... Please help me out in this if you know. Thank you verry much
