I want to set oringnal colour on my parts..in willdfire 4..i cant set the RGB/HSV Colour Code..how i can plase help..
Can you explain better what you are trying to achieve?
If you are trying to change the default color, it cannot change. Only additional colors can be changed by clicking on the color block in the appearance dialog. If the color has an image map, it will not affect the color.
If you can explain better, we might help more.
