ProSelect Behavior
pwilliams-3
ProSelect Behavior
When I call ProSelect() the user is not able to drag a box around
features to select. Is this the correct behavior or should I be coding
something different?
pro_error = ProSelect("membfeat", -1, NULL, &pro_selFuncs, NULL, NULL,
&pro_aSel, &nSelSize);
Patrick Williams | Sr. Application Engineer | CAM Systems | Steelcase
Inc. | 616.698.4078
I also found the solution to this question thanks to Feliks Veysman.
Hello all,
Patrick,
You need to set up selection environment, which is a fifth argument to
ProSelect.
ProSelectionEnvOption env_options[] = { {PRO_SELECT_BY_BOX_ALLOWED,
1},} //whatever else you needed
ProSelectionEnv sel_env;
err = ProSelectionEnvAlloc( env_options, 3, &sel_env ); err = ProSelect(
prompt, -1, NULL, &sel_func, sel_env, NULL, &pro_aSel, &nSelSize); HIH.
Feliks.
Inc. | 616.698.4078
> argument to ProSelect.
> ProSelectionEnvOption env[] ... PRO_SELECT_BY_BOX_ALLOWED, ...
I've not had much consistent success with this since WF,
although it is the only way to do it. Sometimes it works
and (same session) sometimes it does not.
There's a note in the docs implying that it doesn't work for
release 18 and higher "for external users". Perhaps it's a
euphemism for "doesn't work, don't use it anymore".
Perhaps it only works in certain modes, such as selecting
many draft entities in a drawing.
Marc
All,
I have a mfg model in the current window. This mfg model has a part
assembled to it as a fixture. This part has several datum surfaces in
it. I want to use the ProSelect function AND the ability to drag a
window around several of the surfaces to select them. Currently I am
using "membfeat" as the ProSelect filter but that only allows single
selection and not window selection. If I pull up the mfg assembly then I
can use the "surface" ProSelect filter and both selection modes work.
How do I make this work from the mfg model?
Inc. | 616.698.4078
