"Jonathan Hodgson" wrote:
We turned off prehighlighting almost immediately, for one main reason. Some of the models we work with (cast gearbox casings) are extremely complex, and are set up with the cast part as a merge at the start of the machined part. The first 'feature' to be highlighted is the merge feature... which took several seconds for the system to draw the wireframe highlight, every single time you went to select anything. We switched it off, stuck with query select and haven't looked back - we also encourage our new guys to use query select to make sure they're getting the right references.
"Wesley Gegg" wrote:
make a mapkey that does it for you >Edit >Select >Deselect All
