Question on relations
John.Pryal
Hi all,
i have a simple relation d8=p1*p2, where p1=206 & p2=1.0065 making d8=207.339
ok, here is my problem, i want this value to be exactly 207.3400, but rounded to 2 decimal places, so 207.34, now i know about floor & ceil, if i write the realtion with floor (,2), then i get 207.33 (exactly) & if i write the relation with ceil (,2), then i get 207.34 (exactly). So what is the problem you ask, i have the required value of 207.34, but the next time d8 might equal 169.229, floored would give 169.22, but i would require 169.23. Once the relation is written, it is written, i don't want to get into a situation where i have to keep swapping between floor & ceil to achieve a correct rounding up or down. I will give a couple more examples of what i want to achieve, in the hope that somebody understands my requirements.
actual value 223.234, required value 223.2300, but rounded to 2 places, so 223.23
actual value 125.987, required value 125.9900, but rounded to 2 places, so 125.99
ok, hopefully my babbling will make sense to someone.
I just had a thought, is there a way of using floor & ceil in the same realtion, to achieve what i want, if so, how would you write that.
Best Regards
John
If you use floor(value+0.005, 2), this should always round correctly to the nearest value.
For example:
125.987 + 0.005 = 125.992
floor(125.992, 2) will then give 125.99
223.234 + 0.005 = 223.239
floor(223.239, 2) still gives 223.23
This is a useful trick in Excel, or in programming languages which don't have a true ROUND function.
4 REPLIES 4
John,
my suggestion is to test nonrelevant digits on 3rd, 4th, ... place after decimal point.
Try following relations:
if ((d8*100)-floor(d8*100))<0.5
new_d8=floor(d8*100)/100
else
new_d8=(floor(d8*100)+1)/100
endif
-OR-
if (d8-floor(d8,2))<0.005
new_d8=floor(d8,2)
else
new_d8=floor(d8,2)+0.01
endif
Good luck
Martin
Martin Hanák
John.Pryal
(To:MartinHanak)
Thank you for the reply Martin,
i will give it a go. Having said that, if there is an easier solution, i would appreciate it. I am really trying to avoid complex relations, as they prove to be unpopular within the company.
Regards
John
For example:
Thank you Jonathan,
i altered my relations to suit, & now i am getting the values rounded how i want.
Best Regards
John
