Re: Dual Dimensioning in WF4
GRS
There is an option to show dual dimensions but I do not remember it. Also there is an sentence that you type into the options box to get a listing of all of the options available in ProE, can you help me with this? Any help is appreciated. Thanks!
VladimirPalffy
(To:GRS)
Hello Gerald
If you created your own dtl file, you can set it for every new drawing with configuration options (in config.pro):
drawing_setup_file ...path_to_file\your_file.dtl
pro_dtl_setup_dir ...path_to_file
You can create your custom formats and set configuration options (in config.pro):
format_setup_file ...path_to_file\your_file.dtl
Note: in old drawings do you need set dtl file manualy (you can use Mapkey too or ModelCheck)
Vladimir
Best Regards,
Vladimir Palffy
VladimirPalffy
(To:GRS)
Hello Gerald.
Configuration option for dual dimension you must set in *.dtl file for drawing.
dual_dimensioning
List for options is:
no* (deafault)
primary[secondary]
secondary[primary]
secondary
Do you can specify second dim with:
dual_secondary_units
mm*
inch
foot
cm
m
Vladimir
Best Regards,
Vladimir Palffy
Thanks for the info on this.
I realize that the Dual_Dimesion can be set in each drawing but I want it to be set in all drawings. Can you help me with this?
Any help is much appreciated.
Thanks, Jerry
VladimirPalffy
(To:GRS)
Hello Gerald
Vladimir
Best Regards,
Vladimir Palffy
