Release datecode
dleclerc
Release datecode
Does anyone know what the difference between datecodes are ( like C000, F000, M000)?
Denis
1 REPLY 1
Cxxx are preproduction releases
F000 is the initial production release
Mxxx are maintenance releases of an F000 release
Pro/E can be installed from any CD set, Cxxx, F000 or Mxxx.
Windchill may require a mix of F000 CD's and the Mxxx build that you are
installing.
Ben Loosli
Sr IS Technologist
Engineering Automation Systems
L-3 Communications/Integrated Systems
Waco, TX 76715
254-867-4069
