Is there a system parameter for whatever the units of a model are set to?
I am working on a large project that has some models are set to "Inch lbm Second (Pro/E Default)" and others to "Inch Pound Second (IPS).
What I need, is to set a column in the modeltree that will display what are the units for each component.
I know that material files can include a parameter for the units that can be displayed in the model tree, but I do not want to use it because many old parts do not have the correct materials assigned.
There should be a system parameter that I could use.
Thanks in advance,
Ronnie Shand
