Revolve in an oval manner
ptc-800014
HI, I need some help to create a domed oval. I assumed that I would use a revolve with a relation calculation to define the length from center to edge as it revolved. Could anyone help with this calculation? To clarify what i was thinking, let d1 = length from center of revolve to outer edge. I need to say "at revolve angle 0, d1 = Rx" then "at revolve angle 90, d1 = Ry" then "at revolve angle 180, d1 = Rx" then "at revolve angle 270, d1 = Ry" and then d1 = Rx again on full revolution. Any other ideas would be helpful, thanks, Peace, Peter
Instead of a revolve, use a Sweep. The trajectory is your oval that you can sketch, and then the profile is the shape you want to follow the oval.
Thanks Stephen, I stll get a little stuck locking down the centre axis. Do you or anyone have any comments on where im going wrong? Attached are some pics to clarify. The section is set to variable. The section Plane control is set to "Normal to trajectory" Thanks, Peter.
could you email me the model? send it to the address in the email button below this post and i'll have a look.
