Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Thanks for all the responses. By using a couple of new icons (and maybe and a few new mapkeys), WF has the same functionality as 2001. Here's my original question and all responses:
