SUMMARY: View small details in large model
chibouki
Many fast answers! The one that explains the best the solution was
provided by Tyler:
Thumbs up to all the responders, thumbs down to the multiple out of office
replies. By the way, on my side, I can exclude the term " [model] " from
my out of office reply...
David
pgress
(To:chibouki)
> 1. set Quality to 10
> 2. check "Small Surfaces"
> There is no config option for the first item there, the second can be
> set with the option "skip_small_surfaces no"
Which means "1. set Quality to 10" doesn't get saved. You have to
change this value with every new session. Is there any setting to get
this permanent.
Paul
Paul Gress
President
Rad Electronics Inc.
150 Z Executive Drive
Edgewood, NY 11717
(631) 243-7707
(631) 243-7708 Fax
www.rad-electronics.com
I use a trail file for all my "don't get saved" or "no config.pro"
options, like shading quality, maximize window, etc.
Run Pro/E and do everything you normally do and don't want to keep doing.
Before exiting, copy the trail file to your startup directory and rename
it, like "startup.txt".
Edit your Pro/E command and add startup.txt to the end of the command line.
HIH
Rui
> this permanent.
> Paul
