SUMMARY: different fonts in the same line of text...
PAULKORENKIEWIC
I was on the right track... just had to use the FORMAT- TEXT STYLE menu
in 2001... The trick was that you can't get to the segment of the note
thru query select in order to use the RMB PROPERTIES or MOD TEXT STYLE
functionality. I'll include samples of the replies as they differ
somewhat... I'm thinking based on what version of Pro/E you are using:
- Do it by using the modify font style instead of QS
- You have the note changed correctly. I use this map key to select and
modify text style:
mapkey ms @MAPKEY_LABELMod text Style;#MODIFY;#TEXT;#TEXT STYLE;
- Put the P on a second line then change the font then re-edit and move
the line up. (this is for WF!)
thanks to all...
ORIGINAL POST:
0 REPLIES 0
