Save As (Exporting to obj)
mom
I have with succes converted many parts to obj files. The result is very nice. I have problems with some parts, nothing is written to the output file. How can that be? ProE just writes: "0 triangles have been written in output file", but why?
5 REPLIES 5
ptc-1430527
(To:mom)
Hi Could it be because non-solid parts are not supported? This is the case with STL export. Thomas
mom
(To:ptc-1430527)
Yes that could be! Is there a way to make these parts solids?
ptc-1430527
(To:mom)
It depends on the parts. If all surfaces meet, then solidify will do the trick. Otherwise: Thicken from Edit menu can make solid shells out of surfaces.
mom
(To:ptc-1430527)
Hi all, I still can't seem to export some parts to obj. No matter what I try I get the same "0 triangles written to file". I would be very happy if somebody could help me. I am willing to pay for a solution !!! Best regards Michael I can provide parts if somebody is up for the challange...
ptc-1430527
(To:mom)
I have helped out and solved the problem. /Thomas
