Save file
ptc-1035147
Save file
I know that every time that i push the buton save Proe make anotner copy of that file.. and finaly I will have a lot of number of the same file . How can I set proe to remeber only last 3 saves or someting like that. I konw that is the comand : delet old file but that remeber only the last save and i want tha last 3 save.
5 REPLIES 5
You can use Spekan purge. With this tool you can choose the number of save that you keep. This tool can be recusive and it can delete the undisired file.
where can I find this tool ? thnaks
Anyway if someoane else know other solutions please write them here
I have try it and work . Thanks and best regards !
