Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
I know that every time that i push the buton save Proe make anotner copy of that file.. and finaly I will have a lot of number of the same file . How can I set proe to remeber only last 3 saves or someting like that. I konw that is the comand : delet old file but that remeber only the last save and i want tha last 3 save.
You can use Spekan purge. With this tool you can choose the number of save that you keep. This tool can be recusive and it can delete the undisired file.
