Search results showing name not filename
davehaigh
When you copy files, using save as or other methods, you get a new file with a new filename, but the same name as the original file.
The file name search in the model tree search tab shows the name, not the filename in the results window. So it may show you two or more items with identical names, but the file names for each would be different. This can cause confusion and has resulted in the wrong files being modified.
Is there some way to force the results window in the model tree search tab to show the filename instead of the name?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
0 REPLIES 0
