Summary: Ahhhh!! The friday noob question.
dpilkey
6-Contributor
Original Question:
Hello Gurus
wildfire 2.0
When adding dimensions we sometimes change from our normal arrow to a filled dot. Our current procedure:
Point mouse at arrow we want to change--RMB--ARROW STYLE--FILLED DOT--DONE/RETURN. My question: Is there a way to change the RMB selection menu so that I could put the FILLED DOT option right there.
Thanks to all Donald
Answers:
Nope!
You can't change the rmb menu. However you can create a mapkey to help you out on this.
0 REPLIES 0
