Summary - Creating an enclosed note
rdevaux
6-Contributor
Well, I did not get one response saying this was possible.....end of
summary 😉
Rob Devaux
Sr. Tool Designer
ABA-PGT, Inc.
10 Gear Drive
Manchester, CT. 06042-0270
United States of America
(860)649-4591 ext. 120
fax (860)643-7619
rdevaux@abapgt.com
www.abapgt.com
5 REPLIES 5
Sorry thought you would get the easy answer.
Type @[ at the start of your note.
Ron Rich
Staff Mechanical Engineer
Keithley Instruments, Inc.
28775 Aurora Road
Cleveland, OH 44139
440-498-2954 PH
440-498-2890 FX
CONFIDENTIALITY NOTE: This message is intended only for the use of the
individual or entity to which it is addressed and may contain information
that is privileged, confidential, and exempt from disclosure under
applicable law. If the reader of this notice is not the intended recipient,
you are hereby notified that any dissemination, distribution or copying of
this communication is strictly prohibited. If you have received this
communication in error, please notify the sender immediately.
_____
Don't forget, you also need an @] and the end of the note.
Example below:
@[This note is located inside a box@]
Bob
You guys are incredible. Ok, one more time. He already knows how to put
the box around the text, and Bob, you do not have to put the ]@ on the
end. The front one will work just fine.
Bryant (Buddy) H. Hudson IV
CAD/PDM Administrator
Atlas Copco Drilling Solutions LLC
2100 North First St.
Garland, TX 75040
Phone: (972)-496-7328 Fax: (972)-496-7422
E-mail: Buddy.Hudson@us.atlascopco.com
Visit Atlas Copco at:
wrsamuels
(To:rdevaux)
I think @0 is what you want. The pic below is a created dim on a drawing
converted into an inspection dim, and the d replaced with o and followed
with the desired text.
All the ways to impact text in a note or in a dimension that I am aware
of
- @+ = superscript
- @- = subscript
- @# = end script change
- @o = replace the d with the letter o of the created dimension
and enter text, does not work on driving dimensions
- @[ = start boxed text
- @] = end boxed text (used to box only part of a note)
- To control the number of digits displayed in a table on a
drawing
Create relation to "name" = &dim#
On drawing use &"name"[.7] where the 7 is the num of digs to
display
Should here of more please share.....
Feel free to contact me with any questions
Bill Samuels
603-885-2506
JMSCRA
1-Newbie
(To:rdevaux)
This would be true if you wanted to put a box around the entire note. If you
want to box only a portion of the note then you will need the @[ where you
want the box to start and @] where you want it to stop. I am working with
WF2.0
John Scranton
Sr. Designer
Ultra Electronics
UnderSea Sensor Systems, Inc.
