Text and arrow size
Amcare
Text and arrow size
I wanted to know how to change the text and arrow size for all dwgs?
SkyKing
(To:Amcare)
Change Your Configuration Options
DavidButz
(To:SkyKing)
Aaron, For drawing specific options such as text height and arrow size, its a nested process. These settings are not regular config settings, but Drawing Options (File/Properties/Drawing Options). Here you will find choices like drawing_text_height. Set your preferences, then Save the file. Now use the config option drawing_setup_file to set the path/filename so that these settings will be loaded when you start Pro. You can also set the option pro_dtl_setup_dir. David
