I gave the default speed and feed for each tool and when I call the tools for operations like Roughing,finishing etc.. the default value doesn't get updated.
Give me some suggestions how I solve the issue.
I have the same problem since a long time. I'm interested also in this question...
Maybe try to change this in your options setting,
Larry
If you want this to automatically populate without any selections (and update if you change materials) you should use relations in your site file. Something like:
CUT_FEED =TOOL_ROUGH_FEED_RATE
STEP_OVER =TOOL_ROUGH_RADIAL_DEPTH-.005
SPINDLE_SPEED=TOOL_ROUGH_SPINDLE_RPM
STEP_DEPTH=TOOL_ROUGH_AXIAL_DEPTH
Thanks Bill for this grate tip, it works perfectly !! What a lot of time i'm going to save.
Thank you all ...It works perfectly.
I suppose you know.., you can set tool conditions for different materials and then use them in your manufacturing model selecting the stock material:
