Don't forget about the menu mapper on ptc.com to determine unfamiliar menu picks: http://www.ptc.com/community/proewf2/menu_mapper/en/index.htm
Although Creo Elements/Pro 5.0 is not fully mapped yet, if you map from previous versions to WIldfire 4.0 with the exception for detailing, you should see the correct picks for CE/Pro 5.0.
