anyone out there had the UNDO and REDO icons just suddenly go "greyed out"?
they were working a few days back andnow they don't work anymore.
even ->EDIT ->UNDO & ->REDO are greyed out
WF4 / M210
TIA
Mark Steffke was correct. i had 2X protk.dat files and i edited the wrong one. i renamed to XXXX.dat.old and all is good.
thanx Mark
his reply:
I seem to remember that if you have toolkit apps registered, it disables the undo/redo. Im about 80% sure on that. Makes sense because toolkit apps could do any number of things to parameters or geometry, triggered from events, and pro/e couldn't track that if they wanted to.
