Variable shell
amitshah
Variable shell
I need to create a PET bottle with variable wall thickness.
Is there any way where I could maintain variable wall thickness.
NOTE: the share of the bottle is not circular, the base is elliptical.
6 REPLIES 6
Yes.
You can use the Non default thickness option to select the specific surfaces with their own thickness:
But it creates a step in the model !
Do you have any image for reference
No. It will not create steps.see attached.
The base seems to be a circular !
StephenW
(To:amitshah)
If you share an image, you may get better help.
its just similar to it..Where base is not circular and the dimension of the base is thick comparing the upper part of body.
An even gets thicker at the bottle neck.
