Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
What is the best program to view pro-e files, preferably free? I've tried product view express, and just isn't enough! Is there any program that can recognize the simplified representations? Thanks
Hello, I used too free Edrawing with Wildfire 1/2/3. It's a good soft but with the free version, you can't take measures. But, if you want to show only the part or assembly, it's cool. Frank
