WHAT IS MEAN BY ACCURACY?
ptc-2137578
HI FRIENDS I NEED TO KNOW ABOUT THE ACCURACY THE COMMAND IS PLACED-EDIT->SETUP->ACCURACY WHAT ARE ALL THE CHANGES TO MADE IN ACCURACY COMMAND.
hi there... The level of accuracy is very useful if you need to work with(evaluate) very small surfaces or if you need to calculate small dimensions of the model..
This should help: https://www.ptc.com/appserver/cs/view/solution.jsp?n=/32869.htm
