Weight in simplified rappresentation
MauroZovi
Hello, usually i get weight calculation through this code (in relation window): PESO=Floor((7.85*10^(-6)*PRO_MP_VOLUME)*1000)/1000 IF PESO >= 0.5 & PESO <= 5 PESO = Floor(PESO*100)/100 ENDIF IF PESO > 5 & PESO <=50 PESO = Floor(PESO*10)/10 ENDIF IF PESO > 50 PESO = Floor(PESO) ENDIF PESO is for WEIGHT. How can i calculate weight for a simplified rappresentation? Thank you.
Analysis>Model>Mass properties Create an Analysis feature (choose "feature" in the bottom left corner of the analysis window) if you want to use this weight in a relation or a drawing (it will become available as a feature parameter). Be careful of the units and density of all the parts.
