What is the "designate" column for in the "Parameter" window?
kevin.birch
What happens if designate is checked or unchecked?
I'm relatively new to Pro/E and this forum, but a long time CAD (CADDS 5, IDEAS, Mechanical Desktop, Solidworks) user. Thanks!
Kevin,
I can't speak for other Product Data Management (PDM) systems other than
Pro/INTRALINK, but if the Pro/E Designate box is checked, then the
parameter is passed to the corresponding (same name) Pro/I Attribute.
It then can be used inside of Pro/I to be included in table display's,
Sorting, searching (Locate in Pro/I), and so forth.
--Jim Augeri
MCAD Tool Support - Engineering Quality and Tools (EQT)
Honeywell Aerospace
9201 San Mateo Blvd. (MS B-3)
Albuquerque, NM 87113
Phone - 505.828.5808
Fax - 505.828.5500
james.a.augeri@honeywell.com
This e-mail message and any attachments are for the use of the intended
recipient(s) and may be controlled by U.S. export control laws. Any
unauthorized review, use, disclosure or distribution of this
communication in whole or in part without the express written consent of
Honeywell, or the U.S. Government as required, is prohibited. If you are
not the intended recipient(s), please contact the sender by reply e-mail
and destroy the original message and any copies of the message as well
as any attachment(s) to the original message.
