Wheel button is not exiting a command, help?
EvanHannibal
I downloaded the Creo Elements student edition. I was giving it a test run and when I go to sketch something, the wheel button doesn't exit the command. I am using Windows 7. Can anyone help me with this?
Probably you should change assignments of your mouse buttons in the system - the wheel button must be the middle button...
"change assignments of your mouse button"
How do you do it?
