Where is the command "Audit Trail" at Creo 1.0?
HAOWANG
There is a command at Proe 4.0 : Info ==> audit trail , it can generate the "Audit Trail Report", but at Creo 1.0, I can't find it .
Bari
(To:HAOWANG)
I think that this is what you want?
Go to TOOLS tab under Investigate group you have the option FILE HISTORY.
3 REPLIES 3
Bari
(To:HAOWANG)
HAOWANG
(To:Bari)
Hi, thank you very much. This is correct what I seeking, and I think the "File history" is more proper than the "Audit Trail" ^_^
JonathanHodgson
(To:Bari)
Thanks - just Googled to find this answer!
This is where the Command Search function breaks down. If I search for Audit Trail I get no results - because I'm supposed to know that it's now called File History.
That's even less helpful than the "Commands Not In The Ribbon" result (e.g. Mapkeys)... at least with that you can select the command directly from the search results.
Is there a WF to Creo Menu Mapper, like they produced for 2001 to Wildfire?
