Which JAVA version do I need with CREO 3.0 J/LINK
BillButner
Is it the same as the first CREO or did they update j/link?
JensN.
(To:BillButner)
Hi
Hi Jens-Uwe Nixdorf‌,
Thanks for catching this.  I've moved this thread to the Creo Community.
Kael
Kind Regards,
Kael Lizak
Hi Bill,
I found some information, that may be helpful in article CS111722.
  • The J-Link application should not be compiled with a newer JDK than the Java Run-time version used on the clients
Amit
in http://support.ptc.com/WCMS/files/160242/en/PTC_Creo_Future_Platform_Support_Summary.pdf you can find ...
                                                     Creo 2.0                     Creo 3.0                      Creo 4.0
MH
Martin Hanák
