Why dimensions in half view are reversed?
gbenetti
See attached capscreen.
Thank you.
Hello Gabriele Benetti
try following:
1. Create projected view in drawing
2. Move dimmension into projected view.
3. Is it correct now? If yes, change/rotate sketching plane about 90° (in 3D model)
Don´t any other idea...
Milan Bonka
StephenW
(To:gbenetti)
I'm not sure what you were expecting. If you could give more information, you would likely get some help.
Hello Stephen.
When I create manually a quote I have to select two references but in half or broken view I have to select axis like a middle point of dimension.
Then with right clic I select double value but the quote is not oriented correctly.
In the immage you can see the wrong quote (upper) and the right quote (lower) obtained with Milan Bonka suggestion.
In Wildfire release I haven't this trouble.
Probably it's a wrong parameter in file config .dtl or .pro
Thank you Stephen
try following:
Milan Bonka
gbenetti
(To:mbonka)
Thank you Milan.
