I think it is very important command for Pro-E user .
It should be standard module I think.@
The Pro/ASSEMBLY or Advanced Assembly Extension licenses are required to created data sharing features such as Merge/Inheritance, Publish Geometry, Copy Geometry and Shrinkwraps.
