Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
I'm playing about working hard with WF3.0 doing some Published and Copy Geom. The annoying thing is that when I bring in the data from the copied file, its window appears in front of the window that I have all the commands on and I have to keep resizing all my windows to finish the action. Those of you that have been on WF3.0 must have experienced this and I'm wondering if you could share any fix/workaround.
Richard, this happens when you have the copied file open in its own window before making the Copy Geom feature. If it is not displayed in any window before hand it will be retrieve in the nice little window that fits in front of your active model.
Subject [proecad] - Windows overlapping in "Copy Geom."
I?m playing about working hard with WF3.0 doing some Published and Copy Geom. The annoying thing is that when I bring in the data from the copied file, its window appears in front of the window that I have all the commands on and I have to keep resizing all my windows to finish the action. Those of you that have been on WF3.0 must have experienced this and I?m wondering if you could share any fix/workaround. Thanks, Richard A. Black Lead Engineer Eaton Corporation 16900 Aberdeen Road Laurinburg, NC. 28353 Tel: 910-610-1788 Fax: 910-277-3700
