XYZ data
SteveLester
XYZ data
What is the best way to create a pipe/tube from xyz data?
Steve,
I use the offset coordinate sytem datum point tool to enter the xyz numbers.
Start the tool select a coord sys point.
Click in the lower box to make your points.
Change the values.
Then I go to insert / advanced / pipe and follow the prompts.
Not sure if it is the best , but it works for me.
Let me know if you need anything further.
Later
Brian
4 REPLIES 4
Hi Steve,
are those xyz points the virtual corners (bends) or ragular points along the pipe?
Constantin
They represent the intersection of two lines. I think there may be a better way to use XYZ data then INSERT, ADVANCE, PIPE. Possibly a family table. I don't have the piping extension.
Thanks!
Steve,
Change the values.
Later
Brian
Brian,
I tried it your way and it works great!
Steve
