bat file
bmozley
bat file
Pro E users,
What is the file " proe1.psf " in the proe bat file?
Brad
WF 3
Brad,
The .psf file is the preferences file that is used to set environment variables for the launch of Pro/E. These are typically set during installation of the software. You can also edit the .psf manually to add/change environment variables as necessary.
In Reply to Brad Mozley:
Pro E users,
Brad
WF 3
Sean Sullivan
Velcon Filters LLC
CAD Administrator / Product Development Engineer
