Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
My WF2 coord sys creation UI does not have the Type drop down box. It's not that it's grayed out, it's just no there, there's not even space for it above the 3 tabs. The other users do not have this problem and can select the type of coord sys they wish to create. I don't remeber this problem in WF1. Any ideas?
Thanks to NDK at mcadcentral, it seems that you can only create cartesian coord systems in Part mode. You must be in Mechanica to create the additional cyl and spherical coord systems. See attached image taken from Mechanica.
This is not true. While in part/assembly mode you have to pick a feature to offset from and then you can specify what kind of offset you want (ie. cartesion, cyl, shereical). Is there a reason you would want to place a csys without referencing another feature?
You don't need Mechanica to create a coordinate system, you need to select some sort of reference then options will become available.
<-> wrote in message news:154298@model... Thanks to NDK at mcadcentral, it seems that you can only create cartesian coord systems in Part mode. You must be in Mechanica to create the additional cyl and spherical coord systems. See attached image taken from Mechanica.
