just came to know catia does not have a text option in sketcher.
and pro/e has it for so loong...we use this text option regularly for a our work...
th reason i am posting this is....we keep on saying pro/e takes so many clicks..and
this is so bad in pro/e.... and this can be done so easily in solidworks,inventor.....and so on...
well lets appreciate some wonderful things in pro/e!
Yes, true fact. You need to use an external tool like Text2CATIA or paste curves from a dreawing
which in both ways leaves you with 'dead' curves as text..
In ProE you can even have a parameter plotted as text in the sketcher (which may be edited in the TDM Tool)... sweet!
its just a weak workaround...
where as in proe we can have relations between text..and parametric....its powerful.
